Haven't built a PC in a few years, really enjoyed it, but not so much the setup afterwards, tweaking etc.
I have a Asus Maximum X Hero board with 8700k CPU, 16gb (2x8gb) DDR4 3,600 ram.
All setup, I've run the basic bios overclocking option to ramp up 29% at 4.8 (voltage 1.1); it was quite comfortable running 37% up at 5.0 but I doubt I'd notice a difference. I've managed to increase the ddr4 to 2,400 from 2,133 stock, but if I go as high as 3,600, it won't boot and I have to start again.
Not sure what XMP profile is, but that is off. When I turn on, it boost everything and doesn't post.
Do I need to do more than what I've done. Cinemark shows a result of 1554 for CPU stress test, though I suspect that isn't a very conclusive test.
One thing I'm struggling with is cooling. I'm using a H115i on the standard setup (two fans into the extender, then connected to the CPU_FAN, leaving both AIO_PUMP and CPU_FAN_OPT blank). I never seem to find the fans spinning up much (just showing around 1000rpm), even under a stress test (the temps were around 80c on full stress load, generally run 25c in normal operation, with the occasion individual core increase to 50c).
Should I be controlling AIO fans from Corsair Link, or from Bios (do they conflict). I also have case fans from Be Quiet! with PWM support, but can't control them within Corsair Link. No idea what is controlling what!
Any general guidance appreciated.
