- 5 Nov 2012
Hi
I built my first pc up, when I did the first boot the computer started but no display. I did some research and I tried to remove ram and reinstall, I tried to turn pc on again and it displayed on my monitor I was able to view the bios which showed CPU running fine and Ram.
After installing windows I decided to switch off the pc and move it to the corner of the desk.
I loaded it up and again not displaying on monitor.
I have noticed when it starts up the fans kick in and then they slow down then kick back up, on the motherboard b550- a the lights on the dram is orange then goes off, cpu light is red then goes off , vga is white then goes off and boot is green then goes off dunno if this is anything to worry about.
Then I will switch it off and then switch it back on then it will load straight into windows?
Wish I didn’t build it now feel like I have failed lol.
Any help would be appreciated
Thanks
Thanks
