First Time PC buyer
3 Sep 2019
Hi guys,
I will be moving to the UK soon. Looking at getting a decent set up.
I've been a console player all my life. Decided once I get over I want a nice PC set up.
Here is what I have been toying with:
My basket at Overclockers UK:
  • 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £2,805.67
    • Motherboard:Gigabyte Z390 Aorus Pro Intel Z390 (Socket 1151) DDR4 ATX Motherboard
    • Processor:Intel Core i7-9700K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM
    • CPU Cooler:NZXT Kraken X52 AIO Water Cooling Unit - 240mm
    • Memory:Corsair Vengeance LPX 32GB (2x16GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black (CMK32GX4M2A2
    • M.2 Solid State Drive **For Operating System If Selected**:Unwanted
    • Solid State Drive 1:Samsung 250GB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E250B/EU)
    • Solid State Drive 2:Unwanted
    • Mechanical Hard Drive 1:Seagate 3TB BarraCuda 5400RPM 256MB Cache Internal Hard Drive (ST3000DM007)
    • Mechanical Hard Drive 2:Unwanted
    • Optical Drive **Please Check Chassis Support**:Unwanted
    • Soundcard:Unwanted
    • Network Adapter:Unwanted
    • Operating System:Microsoft Windows 10 Home Advanced - Systems
    • Security Software:Unwanted
    • Build Time:Standard Build Systems - Dispatched in approx 7 working days
    • Speakers:Unwanted
    • Gaming Chair:noblechairs EPIC Gaming Chair - Black
    • Headset:AKG K92 Closed-back Headphones
    • Monitors:Gigabyte AORUS AD27QD 27" 2560x1440 144Hz IPS FreeSync/G-Sync Tactical Gaming Monitor HDMI DP
    • Power Supply:Kolink Continuum 850W 80 Plus Platinum Modular Power Supply
    • Keyboard:Ducky One2 Mini 60% RGB USB Mechanical Gaming Keyboard Brown Cherry MX Switch UK Layout
    • Mouse:Logitech G502 HERO High Performance Gaming Mouse (910-005470)
    • Graphics Card:Asus GeForce GTX 1660Ti Phoenix OC 6144MB GDDR6 PCI-Express Graphics Card
    • Graphics Card 2:Unwanted
    • NV Link Bridge - Nvidia RTX Cards Only:Unwanted
    • Case:NZXT H700 Midi Tower Gaming Case - White Window
    • Case Lighting:Phanteks RGB LED Strip Starter Kit (PH-LEDKT_CMBO)
Total: £2,819.77 (includes shipping: £14.10)​
Let me know what you think or what I should change
£2.8K and only a GTX 1660Ti. How does that even happen? You'd want at least a RTX 2070 Super or 5700XT for that monitor and budget.
If you have that budget to spend on a PC then get someone to spec you one on here... You'll get better for your money and if you build it yourself youll save build costs
Are OC the best place to get everything from or split between 'competitor' etc?
quick heads up - best not to mention competitors when discussing pc parts. that company can be named when talking about coffee machines (for example) but not pc parts. best edit them out in this instance and have a gander at the forum rules.
