- 16 May 2013
- Man Cave
Hello guys,
Can anyone give me a hand at all? It's my first attempt at going SLI and I would like to ensure all is compatible and a good choice.
Current setup:
Power Supply: Corsair TX650 V2 650W
Processor: Intel Core i5 3570K 3.4Ghz
RAM: 8GB Corsair Vengeance DDR3 1600Mhz/PC12800
Motherboard: Asus Sabertooth Z77
Graphics card: Palit GTX 670 2GB Jetstream
Now I can get my hands on 2 Asus GTX 670 2GB from a friend in exchange for my Palit GPU.
Could my current setup run the x2 Asus GPU's well, and are they OK cards?
I have an Asus 21.5 inch monitor running atm, and I also plan on adding another 8GB of ram.
Cheers.
Current setup:
Cheers.
I used a 3930K and 2 x 680's on a 750W with no problems. It pulled around 800W at 1.34V - and a decent OC on the 680's (no extra volts) but that was at the wall with 3 monitors, so knock off the extra monitor power and extra voltage from the 3930K and you will be on the limit.
