First Time Small from Factor Help!!!
1 Feb 2014
Hi,
Been wanting to make use of a small form factor case for a while and settled on two options
Silverstone SST-ML09B - https://www.overclockers.co.uk/silverstone-sst-ml09b-milo-mini-itx-case-black-ca-43c-sv.html
Or
Fractal Design Note 202 - https://www.overclockers.co.uk/fractal-design-node-202-mini-itx-htpc-case-black-ca-061-fd.html
Just struggling to decide what to actually put inside as obviously space is limited in both.
The use of the machine is going to be living room HTPC + Current Gen Gaming with a budget between £600-£800.
If anyone has any experience with this help would be appreciated I'm not expecting for anyone to provide a build (if anyone does wish to wouldn't frown on it) just looking for advice. Shall post up a planned build shortly.
