First time water cooler
15 Nov 2013
Cambridge
Hi Guys,
First time water cooler here, so looking for some advice on the below kit? is it ok for CPU only and a bit of expansion later on when i've sorted my GPU situation? Ive already got a Phobya res.
YOUR BASKET
1 x OcUK Tech Lab - XSPC D5 Vario Pump & XSPC Acetal D5 Top Value Combo £79.94
1 x Hardware Labs Black ICE Radiator GT Stealth 360 £49.99
1 x EK Water Blocks EK-Supremacy £49.99
2 x Monsoon 13/10mm (OD 1/2) Rotary 45° - White £6.95 (£13.90)
4 x Monsoon 13/10mm (ID 3/8 OD 1/2) Free Center Compression Fitting - White £5.29 (£21.16)
4 x EK Water Blocks EK-CSQ Fitting 10/13mm G1/4 - Black £2.99 (£11.96)
Total : £236.54 (includes shipping : £8.00).
Looks okay, is there any reason you went half and half on fittings?
If you will expand the loop only by a few blocks and rads, then i would probably save cash on the pump by going for EK 4.0 and grab a better performing radiator.
Yeah, some are hidden from view so to keep costs down;) Can you suggest a better Rad?
This will fill up most of your rad space and give the best performance for the cash.
YOUR BASKET
1 x EK Water Blocks EK-CoolStream PE 360 (Triple) £49.99
1 x EK DCP 4.0 Pump (12v) £39.98
1 x EK Water Blocks EK-CoolStream PE 240 (Dual) £39.95
Total : £226.93 (includes shipping : ).
Alternatively, you can just use a single premium 360mm rad. First choice of these rads for me would be the RX XSPC V3. Having said that, you can get away with a single 360 for a cpu and gpu, these rads are great for the cash!
YOUR BASKET
Thanks for your help.
