Hello,
I've been messing around with watercooling in two computers lately. I haven't watercooled before, so i've run into a few problems.
The first computer failed the leak test. a jubilee clip wasn't tightened down enough, and some coolant ended up on a PCI-E slot. This wasn't a lot - as soon as I saw some fluid leaking from tube I switched off the PSU (that i'd jumped) and tightened the jubilee clip. I'd say only a teaspoon of fluid ended up on the PCI slot.
Here's a quick picture of the first PC. I took it hurriedly, so sorry about the focus. I've also disconnected the video card in an attempt to dry it out.
You can see the PCI slot that the coolant got on. I have the waterblock, under that is a square motherboard heatsink thing, and under that is the slot that the coolant landed on (the long one under the RAM).
This computer now fails to boot. I originally thought that it would be fine since i used coolant instead of distilled water. I thought the coolant would be non-conductive, so I plugged in the graphics card and turned everything on. The fans start spinning (the fans are connected to the motherboard sockets, not the molex ones) but I don't even get motherboard beeps.
I've taken out the CMOS battery to clear the BIOS. That didn't work.
I then tried removing the graphics card and booting with just the processor and RAM installed. There were no beeps.
I tried booting with just the processor installed. There were no beeps.
Does this mean that my motherboard is now broken? I can't believe that such a tiny amount of fluid has wrecked my computer! I've read about worse watercooling catastrophes that have ended up alright!
I have ordered some isopropyl alcohol to put on the PCI slot. Will that be enough?
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Determined not to repeat the same problems with my second computer, I tightened every jubilee clip thoroughly. When the leak testing began, I had a leak at a barb on the reservoir. I drained the system, tightened the barb and that crisis was averted.
However, when further leak testing began I noticed a HUGE leak by the motherboard. I was really surprised by this given that i'd checked everything thoroughly, but it turned out that the leak was coming from the CPU waterblock itself.
Here's a picture of the offending article:
This is a Koolance 350-AT waterblock.
I've tried taking the o rings out and putting them back in again, but I still get leaks. I think the best course of action is to buy new O-rings.
According to the Koolance website, I need an O ring with an outer diameter of 21.5mm and a thickness of 1.5mm.
Unfortunately, ebay only seem to list O rings with an inner diameter. Does this mean that I need an O ring with an inner diameter of 18.5mm?
I get this value of 18.5mm from doing 21 - 1.5 - 1.5 which gives 18.5mm as a result (if you draw a picture of two concentric circles and mark on the thicknesses and outer diameter, you can see where i'm coming from).
Also, there are two O rings in the waterblock. Do I need to replace both of them, or just the big one round the edge?
Thanks for reading. I'd like to see what some of the more experienced people have to say on this.
Can you wreck a motherboard with such a small amount of coolant?
Can you figure out the ID of an O ring from it's thickness and OD?
I look forward to hearing what everyone has to say about this.
