First time WC! Help please :)
1 Dec 2011
SW3
So ive finally decided to give WC a go :)
Will only be doing my cpu for now, but will be adding a new GPU to the loop.
The parts i have are:
Corsair 800D
MSI Mpower Z77 Mobo
I7 3770K CPU
I need everything, cpu block, rad tubing etc so could anyone put together a list of stuff that fits together? Or a complete kit?
I can also buy most of it second hand but will buy tubing and fluid + fittings separately.
EK supremacy cpu block, Laing 18w ddc or a Laing D5 pump, you can get an EK after market top for the pumps that includes a reservoir for both types of pump, 5/8th x 7/16th xspc tubing(colour is your choice), EK psc compression fittings in same size as the tubing, xspc 360rx radiator should suffice for cpu+gpu at a later date.
