First Timer - Need help with Spec
12 Jan 2005
Bristol Massive
Morning all,
My current PC is on his last legs so looking for a totally brand new build. I have done a few upgrades in the past but never a complete build. But I'm going to bite the bullet and try and build this one myself.
I have a budget of £600-700 maybe a bit more if needed. The main use would be Gaming and General use. I have a 19" Monitor/Keyboard/Mouse so just the base unit I'm after.
Looking for someone to help me pick the easiest build that should be compatable and pretty easy to put together.
If anyone could help that would be ace. :)
Thanks
I like both spec's, will mill over it today.. :cool:
I Know I need some Artic Silver 5 also that's no problem. What about an Anti-Static band is it worth getting one? or just ground myself?
Just want to be careful when putting this together that's all. Thanks for the spec's btw guys, they both look like they will do the bussiness for time to come. :)
Will_3rd said:
Just touch a radiator or your PSU
Will do. :)
Quick question about the case, I dont mind paying an extra say £30-£40 for it.
What would you recommend aound the £60 mark. I do like the look of the Thermaltake - Tsunami Dream. :cool:
