Hey all,
After 2 years of running my system OC'd on air, it's time to go water and do a little upgrade.
looking to upgraed from 3570k (@4.4) to 4770k and from gtx560ti to gtx770 and water cool both the cpu and gpu.
Been reading the sticky threads all morning and have been checking out parts etc. This has left a number of questions.
so the spec system will be
i7 4770k, want to OC to at least 4.4ghz
gigabyte z97x-ud5h
2gb gainward gtx770, want to OC.
xclio case can take internal 240mm rad
would like to have a 5.25" bay reservoir but i'm lost in the detail of what size fittings are needed, what side tube fits these fittings and how to split the pump outlet into 2 parallel flows for each part of the system.
not looking for the cheapest solution, just a decent performer without any extra bells and whistles that are unneeded.
how do i know what size fittings to get? each website seems to give different to little info on exact part fitments.
am i best getting a kit and expanding it to take the graphics card?
how do i split the pump output into parallel circuits and back again before the rad?
fan control, is the mobo ok for controlling the rad fans or is a controller really needed?
and lastly, is a 240mm rad with 1L reservoir enough to cool both the hot bits?
thanks for reading.
gigabyte z97x-ud5h
thanks for reading.
