- 1 Dec 2015
Yeah they are from the front and a purchase is next for an internal USB
Was the pump at 100%by default ?
The pump appears to be at 100% but bios isn't that clear in the options, unless I am being thick.
Also I woke up this morning to the monitor having small amounts of grey and green artifacts. I haven't had much chance to look into it but when I switched the monitor to HDMI for Xbox they seem to be there still and when switched PC to my TV on other HDMI they were gone so I am presuming a faulty monitor. Will run some more checks later to be sure.
I will check the AIO pump stuff in a while but as far as the monitor goes, I just changed the DP cable out for a HDMI and the artifacts have gone. Just ordered a new DP cable from the rainforest for tomorrow as I don't have a spare.
I do find it hard to believe that a cable can fail in two days of usage, is it possible for the display ports to play up on the graphic card and not the HDMI or do they all play up at once if there is a problem?
It was cable packed with monitor mate
Checked the bios and AIO pump is now running at full speed. It was plugged into the right header, just not setup correctly. Thanks again for your help![]()
Hi mate, PC is still running very well, but I will look into another 140 for the front as I agree with you about the GPU getting more direct air.
Had a crappy month so not had much time to tinker with PC but I must sit down soon and overclock the 1600![]()
Yeah things will get back to normal soon hopefully. Purchased a 3D printer also to play with, I am going to be busy![]()
Yeah maybe, I also ordered a 5 port USB card with an internal USB 3.0 internal 20 pin connector, so I ordered a 20 pin-two usb adaptor which allows me to plug the front usb internally.
My only worry is ruining the look inside the case as the card and adaptor is not the best looking things.
Its a shame you can't get a shroud of some kind for them.
