Hi all,
Not really a ‘live’ build log since I’ve actually recently finished it, but I thought I’d post some work-in-progress shots since I bought most of it from Overclockers and there may be others here planning a build with similar components.
First the list of components
WIth my motherboard choice I've allowed for a future expansion to SLI, although the GTX 1070 is certainly enough for now!
I chose this case since it’s designed for water cooling, got some great reviews and was at a reasonable price point. The case can just fit a 420mm radiator in the top, although it must be slim (rad + fans thickness < 55mm). There's also room for a 2nd radiator in the front, which I might need if I add a 2nd graphics card one day. This is the loop layout I went for:
I chose to route one tube behind the motherboard tray to keep things clutter free. I wasn’t 100% sure if this would work but that was the plan.
To keep this manageable I'll continue in a new post.
- Case: Fractal Design Define S, with window.
- CPU: i5 6600k
- CPU block: EKWB Supremacy EVO – Acetal and Nickel
- GPU: MSI GTX 1070 Founders Edition
- GPU block: EK FC1070 GTX Acetal and Nickel
- (^ bought the OcUK Tech Labs 1070 GTX card, to save the stress of dismantling an expensive bit of kit)
- PSU: EVGA GQ Gold 750W (hadn't planned on this, but my old PSU went bang midway through the build!)
- Motherboard: MSI Z170A SLI Plus
- RAM: Corsair Vengeance LPX 16 GB (2x8) 3200Mhz
- SSD: Samsung 500gb 850 EVO + reuse old SSD from previous system
- Radiator: Alphacool NexXxos ST30 420mm
- Fans: Akasa Ultra Quiet Viper 140mm
- Pump reservoir combo: XSPC D5 Photon 170
- Compression fittings: EK ACF, black
- Quick disconnect fittings: Koolance QD3
- Coolant: Koolance LIQ-702, yellow
- Tubing: XSPC HighFlex hose, 16/10mm, clear
