Hi Everyone,
I think my Antec 25 Kuhler H20 620 is finally starting to show its age, my i5 2500k at 4.5Ghz is starting to hit towards the upper 70s under load and climbing.
I would quite like to have a go at creating a custom loop just for my CPU
My case is a Zalman Z9 Plus which has space for 2 120 mm fans along the roof so I should be fine with a 240 mm radiator.
Can anyone recommend any cheapish water cooling kits and any advise for a first attempt. For now it will only be the CPU that I will be cooling.
CPU = i5 2500k
Mobo = Asus P8P67 Pro
Psu = Seasonic M12II-850 Bronze (850W)
Alternatively I could just pick up an Antec Kúhler H2O 950 Liquid CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-AN
What are the advantages of a customer loop over a bundled pre sealed water cooler?
CPU = i5 2500k
yes indeed!
I will have a look through.
