I've been running an air cooled Parvum case for the last year or so, but I stumbled upon a water block for my now old fashioned Asus Strix 980. I snapped it up thinking I may water cool at some point, but ended up with a little but of budget creep and got it built straight away
So, on board we have lots of last-gen gear. Still gives me plenty performance for the games I play, so wont be upgrading any time soon.
Photography is from my mobile shot on my dining room table with crap light, do not expect amazing photos
Intel i7-4790k
Gigabyte Z97N-Gaming 5
Asus Strix GTX 980
HyperX Savage DDR3-2400 8GB RAM
HyperX Savage 240GB SSD Boot Drive
Samsung 850evo 500GB Steam Drive
EVGA Supernova G2 750w PSU
NZXT Manta mITX case
NZXT Grid+ v2 fan controller
NZXT Hue+
For Watercooling:
EKWB Supremacy MX
EKWB Strix 980 GPU Block
EKWB 100mm Res / D5 combo
EKWB Vardar 140mm fans x2
EKWB Vardar 120mm fans x2
Magicool 280mm Rad
Magicool 240mm Rad
XSPC compression fittings x10
XSPC 90deg connectors x4
XSPC 45deg connector x1
XSPC 14mm PETG tubing
Here is my old build, dodgy back drop and all:
And it shall all be transferred into this curvy beast:
https://sta3-nzxtcorporation.netdna...ct_image/image/745/large_f9912cb33cf750be.png
** Do Not Hotlink Images **
First things first I decided to strip down the chassis. It's a small case when you take the bulging side panels off so it's a whole lot easier to access things with everything off and removed:
(told you the photography was going to be bad
The next thing to do was change the colour of the motherboard. Typically for a last gen Gigabyte "gaming" board it's black and red. I wanted this build to be pretty tame colour wise, apart from coolant, so pulled the heatsinks off, plus the RAM and SSD for a quick spray.
I'm using a spray called Fulldip. It's like plastidip but has a lot better coverage. I got it from a local shop called matt-pack, only about £6 a can so good value too, I'd certainly recommend the stuff.
I'm quite happy how it turned out, especially the motherboard which IMO looks great in all black.
Next I fitted the rads to the case. NZXT claim this thing can hold two 280mm rads, which is a lie. I've looked at the specs for the Kraken X61 and the radiator is really narrow. I think there are perhaps one or two rads that are that slim which could easily be used for the top mounts. However, the common rads are all 5-10mm too large, hence why I had to use a 240mm rad.
Next issue, the cut-outs for the radiator ports are about 5mm too narrow for the radiators I'm using, see a theme here? My solution was to mount the radiator in the case and use the fans as pull only, not ideal but what's a degree or two going to matter?
Wrong I was! Due to Gigabytes stupid 8 pin CPU connection location, something is going to have to change. There is simply no way of getting the cable attached with the rads installed like this, especially with the quite inflexible stock EVGA cables.
So out comes the hacksaw, grinding discs, wet and dry and plenty of bad language. I have no idea what they make this case out of but my dremmel had real trouble getting through the steel, but fortunately a junior hacksaw made relative easy work with it, but not as neat. A quick spray of black paint to cover the silver edge and the chassis was made wide enough to support the radiator ports.
It's still really tight to fit the 8 pin in with the fans, but they're 5mm thinner and a bit narrower so if I installed the cable before the fans I could get it to work, as you can see.
As you can also see in that picture there is virtually no space for the res/D5 combo. I could mount it horizontally but I'd need to fashion something up to mount on the rads/fans which wasn't going to happen. I decided therefore to mount the pump in the basement, keeping it out of the way and leaving much more space in the chassis.
More to come later...
Intel i7-4790k
Asus Strix GTX 980
NZXT Hue+
For Watercooling:
EKWB Supremacy MX
Magicool 280mm Rad
Magicool 240mm Rad
