- 28 Dec 2017
- Beds
[progress/photo album: https://imgur.com/a/2M62lFG ]
Hi all, so I won a competition over Christmas for a load of WC gear from Aquatuning, on the basis that I review it. I decided to start a new build to justify the cooling potential, as I don't normally overclock or run particularly high-end parts.
For me, a massive factor in any build is noise, so my main gaming rig has a low-TDP chip and passive heatsink, for instance. What appeals to me about water cooling is first quietness, second aesthetics and the fun of creating it yourself/tinkering, and performance/overclocking comes third. Nonetheless I figured I'd better get a k-series chip and upgrade to a GTX 1070!
It took a while to plan and spec up all the parts I'd need from Aquatuning, with lots of advice from them. At the same time I was sourcing components and planning a few extra things. I've been reading up on water cooling for maybe a year, and waiting to take the plunge. I have lots of experience in working with wood, metal and plastic so figured I had the skills for a hardline loop. Case mods are also fun for me so I'll be adding a few bits of trim/vanity stuff like a PSU shroud.
Anyway enough waffle, time for specs and then photos!
CPU: Intel Core i5-4690k (delidded during this build, Thermal Grizzly Conductonaut applied)
Motherboard: Gigabyte Z97X-SLI (with heatsinks anodized black to match the build)
Memory: 16GB (2x8GB) Team Group Xtreem DDR3 2666MHz
GPU: EVGA GTX 1070 Superclocked
SSD: WD Blue 240GB
HDD: 750GB 2.5" 5400RPM (low speed to keep noise down - hard drives are the noisiest component in my other PCs)
PSU: EVGA 600B Bronze rated
Case: bequiet! Pure Base 600 (surprisingly accommodating to build in)
Cooling setup (all Alphacool):
XPX CPU block (black)
NexXxos GPX M01 block for Nvidia GTX 1070 (reference PCB)
Eisbecher 250mm reservoir with VPP755 pump (D5 style)
NexXxos 360mm radiator - 45mm thick
NexXxos 120mm radiator - 30mm thick
16/13mm acrylic tubing, satin
Cape Kelvin Catcher clear coolant
Fittings (all Alphacool, black):
16mm Eiszapfen hard tube fittings
Eiszapfen L-connector, rotatable (for making right-angle connections)
Eiszapfen 2-way ball valve (for draining)
Eiszapfen screw plugs
M3 hex head screws
Corsair SP120 fans for radiators
bequiet! Pure Wings 120mm and 140mm for air intake
I've also used an abundance of cable extensions, splitters, fan distribution (more on this later) etc.
SSD: WD Blue 240GB
M3 hex head screws
