first watercooling atempt
10 May 2009
hi there i am about to try to water cool my q9550 set up i have never done this before and i just would like someone to double check make sure i've got it right
i have been doing a lot of research over the theory and design of water cooling and for my first try i am only going to focus on the to keep the water loop as easy as possible.
As this is a cpu only water cool i have gone for a 5.25" drive bay reservoir by xspc and have also decided to use the delta v3 cpu waterblock from them i have gone for compression fittings to try and keep things neat and have got anti kink coils for the hose. i am going for xspc rs120 radiator.
NOW AT THE RISK OF SOUNDING DUMB!
is it best to have the fan suck air into the radiator or exhaust it out?
sorry to sound silly just wanted to double check this quite important aspect
Thanks a lot confused:
Straight from martin liquid labs testing conclusion (independant testing of your rad)
Push Vs Pull - This depends on fan speed/power. The high speed fans at 2000RPM with a 38mm fan thickness provided the best performance in a push condition. The slow speed fans with 1350RPM with a 25mm fan thickness provided the best performance in a pull condition. I would estimate that performance line is likely to cross in the 1500-1700RPM range where they are equal. So.... slow speed = pull, high speed = push, medium speed = it doesn't really matter.
Just to confirm what was said in the review quoted by shadow, I have the RS360 myself with some lowish (1100) RPM fans, they too work best in pull rather than push.
You seems all set, enjoy :)
If you're only man handling a 120.1 rad then this is something you should quite easily be able to actualy try for yourself when you get everything setup, its only a matter of swaping one fan round. You don't even need to drain or anything, just leave a tiny amount of extra slack in your tube run to the rad.
but p not s noctuas. with s noctuas on radiators you would have better cooling blowing on the rad yourself!
