First watercooling build.
21 Jun 2006
UK
Hi thanks for viewing, any advice would really be appreciated.
CPU block fitted as per the manual, screwing down until the thread stops.
EK Velocity CPU Block
8086K (Delidded)
2 x 8GB 8 Pack DDR4 3200
Update.
Removed the waterblock and backplate and refitted everything and its up and running now with no issues!
Trimming the rubber gasket made a big difference as some of the soldered pins on the back of the motherboard were overly long and were catching.
