First Watercooling idea\ plan so Advice Needed
28 Oct 2006
stoke on trent\bromsgrove
Hi folks
I have been on here a while now & with your help can you lot of mad nutters with your great knowledge... plan me out a water cooling system for my rig ?.
all i know is that i can put a rad on the top part of my case, coolmaster master rc-1100 cosmos s.
but i would like someone too put a list together please for me...
i have about £ 250 or a bit more to spend on the full kit & Feser One UV Reactive Coolant. what i am using in my Zalman Reserator1 v2 Fanless Water Cooling System on my testing & work amd rig.
Many thanks all :D:D
i7, 920 cpu clocked to 3.20 as i am using the intel standard stock fan.
asus p6t deluxe oc palm edition, 6GB corsair xms3 pc3-12800c9 running at 1604 Mhz, zotac geforce gtx 280 amp 1024mb gpu, coolmaster master rc-1100 cosmos s case with 3 extra fans installed, enermax galaxy 1000w psu, running x64 bit pro sp2
Hi, sorry to be rude but i'm finding it really difficult to understand your post. I assume that you're using Zalman Reserator1 v2 in your work computer and now you would like us to help you spec a custom H20 setup for your home computer?
The best place to start is with the excellent guides that are out there. That way you will have a better understanding of the various features within blocks, rads and tubing and will hopefully be able to come back with a spec of your own for us to comment on.
Once you have read the OCUK guide / MikeTimbers guide, Try these:
Xtream Systems - Guide To WaterCooling and Leak Testing - ALL New WaterCooler's Read Before Posting!
Overclock.com - Beginner's Guide to Watercooling
Overclock 3f.net - Water Cooling - Quick Install/Leak Testing guide
no worries, i have got a amd rig at home what is used for work now & that is cooled using Zalman Reserator1 v2 set up.
but now i have this I7 New rig & i would like some help on watercooling kit as there is so many to choose from & it will have to fit my case nice & neat too.
cheers
