Hi there guys,
Have just bought myself a new Q6600 rig, with the MSI Neo-2, and it's currently overclocked to 3200, with idle temps of 41degress and full load of about 55 on all 4 cores using an arctic freezer pro 7.
I'm looking in to a watercooling solution in order to get the temps right the way down, to give me soem more room to overclock... However, I have never watercooled before, and know for a fact that a W/C setup will not fit inside my case (Atrix something or other with big digital display...)
So, i'm after some help from you guys in order to spec a water rig in order to fit in to a new case (included as part of the spec). I've been looking at the Thermaltake Tai-Chi, however have read some dodgy comments on the reliability of the waterblocks etc. A few of the watercool kits don't seem to have rave reviews either, so I was thinking of specing each piece individually - but then I really have no idea...
Cases - I'm open about, but i'm big on my PC being as silent as possible, as I hate fan noise with a passion!!!
Ideally, for all of the components I have a budget of around 230 quid max - the tai-chi comes in at about this...
Any help would be great, or an msn watercooling contact would be great - if you could pm me, I would appreciate a messenger link
Thanks guys...
Thanks guys...
