Hi Guys,
I'm putting together a new Z77/IB build and aesthetics do mean quite a lot so a watercooling setup will obviously help achieve that. I have a Corsair 600T case and will be getting a full acrylic side panel from CyberDruidtheModGod soon with any luck, so the guts of the computer will be on show. Yeah, I'm playing with cable management and will be using BitFenix Alchemy cables and sleeving the cables BitFenix don't have.
ASUS Sabertooth Z77
IB i5 3570K (Hope to OC past 4GHz at least)
2x4GB Corsair Cerulian Blue LP 1600MHz
Crucial M4 SSD
Corsair 600T Case
PSU *NOT CONFIRMED - Likely Corsair AX850*
GFX *NOT CONFIRMED*
I have never done a watercooling setup before so the whole process is completely alien to me. I'm used to having a huuuuge chunk of metal heatsink strapped to the motherboard and hope the board doesn't bend/snap under the weight lol
Could you please suggest a setup that will easily fit in this case for me? I do have value somewhat in mind so an ideal setup for me would be £150-175 - at this range I realise I'm looking at CPU-only loops but would like the possibility to easily add GPU cooling to the loop in the future. I would like white tubing or the same kind of blue on the Corsair Cerulian LP RAM - I've seen the horror stories about blocks 'gunking' up when using coolants etc, so i'm keeping it clean and simple.
PS. I'll be using all 6 hard drive cages in the case and need only 1 5.25" bay - this is what'll set the challenge I think.
ASUS Sabertooth Z77
Crucial M4 SSD
Corsair 600T Case
GFX *NOT CONFIRMED*
I knew in my price range I wouldn't get a lot - certainly not any sort of complexity to allow for CPU + GPU cooling, but I thought it would be enough for a decent single CPU loop system.
