After accidentally slipping into and looking at the case gallery, I finally decided to jump on the band wagon after much deliberation in the past. I've looked a lot at water cooling and feel confident enough to attempt it.
My rig is in my sig, I'll be adding the GPU later as it'll probably take some time to find a decent block for it.
Here's my attempt without the fitting. I know I'd need G1/4 13/19mm but not sure where to go from there completely or what would be best. I'm buying a carbide 540 soon so this is where it will be all be homed.
My basket at Overclockers UK:
Total: £200.71
(includes shipping: £11.10)
How does this look?
- 1 x EK Water Blocks EK-XRES 140 D5 PWM (incl. pump)= £86.99
- 1 x XSPC EX360 120mm Radiator - Black= £42.95
- 1 x Mayhems X1 Blood Red Coolant= £7.99
- 1 x Mayhems Ultra Clear Watercooling Tubing (12 - 34) 13/19mm= £1.69
- 1 x XSPC RayStorm CPU WaterBlock (Intel)= £49.99
Total: £200.71
How does this look?
