First WC finally finish!
I know silly mistake. I'm getting a delivery on Monday of the tubing. I'll change it. It's my first build. Is the rest of loop correct once I swap the tubes over ?
Well for a start, you can put from the graphics cards straight into the cpu inlet, then from the outlet to the rear rad, from the rear rad to the res, there's no benefit running a rad between them and it only makes it more messy.
Actually I can't really work it out from the picture, but you should be able to get what I mean.
I take my ax850 psu is enough for my system ???
Im re-doing the gpu blocks as well.
I'm sorting it this weekend m8. How's yours working out?
When you getting your gpu blocks?
I would have thought your PSU is ample as that tends to be
the choice for most builds with 2 x 680's.
Blocks are out soon according to customer care Germany.
So gives me a chance to safe some dosh.
Mines better than what i thought it would be.
idles mid 30's,gaming low 50's best of all doesn't break 70
when messing about at 5Ghz.:D
So all in all money well spent :)
