Fit Case?
5 May 2006
HEy guys. I was wondering if a specific motherboard will fit in this case. Heres a link to a review of the case: http://tomshardware.co.uk/2005/11/29/making_a_case_for_the_lan_and_officeuk/page3.html
that link has a picture hal way dwon with motherboard compatability info in red on a picture of the case.
Heres a link to the motherboard its the top one on the page : http://www.overclockers.co.uk/acatalog/Socket_AM2_Asus.html
Heres two more links for further info about the motherboard : http://www.asus.com/products4.aspx?l1=3&l2=101&l3=0&model=1283&modelmenu=1
and
http://rog.asus.com/product_crosshair_spec.html
The latter of the two has case compatability at the bottom.
Thanks guys hope the links work.
It would say if it did. But imo, and probably most others on here, that case really isnt worth the money. There are much better cases for the same ammount, and cheaper.
taz488 said:
antec sonata 2, i have it, psu great quality, loadsa space, it beautiful. overall rating is BUY IT NOW
Yep this is a good case and psu combo. If you were willing to spend a bit more, a LianLi PC7 and a 400w~ psu would be a good choice aswell.
Not to surw about the look but good spec though. I am a looks man really not to over the top thts why i liked the other case maybe a glass panel not a must though.
If you want that gaming look, then a Thermaltake Soprano with a window, coupled with a Seasonic S12 430w PSU, and then some cathodes could do the job :)
