all you need is a T piece low on the loop with a tube going off the T with a end on it. Simples . Seen quite a few with ball valves on the end so you can just connect a spare tube and get it out of the case easier
no point wasting money on a qdc for this job if you want to do it. get a female to female 1/4 inch and a 1/4 inch plug. then you can use a normal fitting to fasten to it.
or just use a ball valve
