Fitting a motherboard into an iCute case
21 Dec 2005
Hi,
I've just fitted my motherboard into a new Icute case, the problem is, the motherboard plate has a load of raised sections for the holes I use meaning that using brass spacers would put the mbo in the wrong place to line up the ports with the back plate. I did trywith spacers, but wasn't gonna happen, so instead the mobo is attached stragith to the raised sections of the back plate. It runs fine, no problems, but could this cause a problem later? I did put washers between the screws and the mobo top side. Any Ideas?
If its anything like the cheapo case I have in this house it will be fine.
The lumps which you screw into are there instead of using spacers
