Fitting a Thermochill Rad
20 Apr 2006
Leeds, UK
Can anyone advise on the best way to fit a PA120.3 Rad ?
Have a Lian Li PC-G70 Case, and will be looking at roof mounting the is radiator. However, the diagram available on Thermochill's website advises 112mm holes to be cut for the Fans.
Dremelling the hole's seems to me to be a massive waste of effort and time, with them being circular.
Would a hole saw do the job ? Or another tool ? Can anyone recommend something for this job ? Price of the tool is no barrier, really.
I can but you will have to dremel the hole`s,buy the thremochill fan grill to match your rad and cut the grill to fit on your case.
Agree with clone - have two cases with watercooling and always use a grill as the template.
The Thermochill rad grills are particulaly nice so worth buying anyway.
Remember to check and double check everything before cutting, making sure on best and safest direction of rad and allowing for pipe clearence.
Does anyone know if the HE120.3 and PA120.3 have identical mounts?
I currently have a HE120.3 mounted to roof of my case if I were to change to a PA120.3 would the current fan mounts be correct?
Yeah the he and pa series are different. I have templates for both though if you want me to email them to you. Also if roof mounting try and make sure you have access to bleed screw - makes bleeding system so much easier
