This is getting on my nerves I can't fit it properly, im not sure if one of the black catches is broke or not ill try explain it best I can first with a picture:
The black clip that holds the heatsink to the motherboard has a screw going through the middle that you twist after its through the motherboard hole and the screw drops down and holds it in place under the mobo.
The problem is in one of these clips the screw is already dropped down and it won't fit through the motherboard hole..
Is this normal?
I'm afraid of braking my mobo, I have put a lot of pressure on it and it just won't go through.
hope this was clear
Is this normal?
hope this was clear
