Hi all,
I need to fit a blind above a window which has a steel lintel. I understand that I can use self tappers to screw directly into the lintel, without rawl plugs, but what I don't know is what size drill bit i'll need and which size screws to go with this.
Can anybody recommend the correct hss drill size and matching screw size?
Cheers
Cheers
