Fitting CD Player 206
31 Mar 2010
Lancashire
Just wondering if anyone can help me here. My brother has a Peugeot 206 2004 that had a Sony cd player in it which became faulty. He bought a JVC head unit and I fitted it this afternoon. The CD Player seems ok and works, however it does not turn off when the key is taken out of the ignition. I've done a couple of players before and it was never an issue. The paperwork suggests that for some cars, the red and yellow wires may need swapping over so I tried this and it still does the same thing.
What do I need to do in order to get the CD player to turn off when the key is taken out/ignition turned off?
Thanks :cool:
Sounds like you may well of wired it in wrong. Double check you've connected it up right in the loom.
