Hi all,
The next fun stage, and that which I am least looking forward to, is fitting cabinets to my kitchen walls.
I have two to fit in a corner which I'm not worried about at all, but I have a run of cabinets 2m long to fit to an uneven wall. There is a straight section about 1m long which then probably curves away by 25-30mm over the next metre.
The base units were gone as I was able to scribe them to the wall and even up the gap end-to-end, but wall units do not have the same provision for footing to uneven surfaces that base units do.
How might I get around this?
