Noob question here, but I had a problem at the weekend when I went to have some new tyres fitted to my vRS, as apparently the locking wheel nut key wasn't returned when I had my brakes uprated.
They managed to force the old locking nuts off, but didn't have a replacement set to fit, so they fitted the 4 standard nuts, and I've bought a set of McGard Ultra which arrived today.
So, I'm aware that when you fit wheel nuts you're supposed to screw them in with the wheel off the ground, and then tighten them on the ground, but is it necessary to jack the car up to screw the locking nuts in, or can I just screw in and tighten them without jacking the car up?
I only ask as it's cold and I'm a girl and would like to get it done as quick as poss, but don't want to affect the balance or something? (don't really know why you're not supposed to tighten the nuts with the wheel off the ground)
Any help appreciated.
