Hi
Have just bought a new Asus P7P55D-E that comes with the Q-shield I/O shield plate - which appears to have 2mm thick foam on the motherboard side. I have installed the plate to the case without a lot of hassle, but I am having a problem aligning the motherboard with the stand offs.
The right side of the motherboard (looking at the case from behind) is not a problem to align, but because of the thickness of the I/O plate (I think) I am having problems aligning the left side of the motherboard. It appears to be 3-4mm out which I can resolve by applying a reasonable amount of pressure to a corner of the motherboard.
Is this normal ? and is it safe to fix the motherboard to the case having had to use that tension in order to align it against the stand offs.
Also the keyboard PS/2 socket has a metal tab surrounding the socket. Can this be removed ? I understand it is probably for grounding, but if the I/O shield has metallic properties (presumably for this purpose) is it needed ?
Thank you
Thank you
