Im going to buy this motherboard, 512MB Power Color HD4850 OC, PCI-E 2.0(x16), 1986MHz GDDR3, GPU 665MHz, 800 Cores, 2xDL DVI-I/ HDTV - http://www.overclockers.co.uk/showp...90X (Socket AM2) PCI-Express DDR2 Motherboard
But im starting to panic, i dont know much about how to fit the parts into my machine, and im wondering,
does it have to fit on a certain side of my case? my case only has its left hand panel to fit stuff to, (left hand panel when looking in same direction as the case. right hand panel is a door "NZXT Lexa case"). Just having a little worry as all the card slot and the ram slots are in different positions to my current mobo, its an old one, and i have no idea how to do it.
if anyone is able to clear this up for me i would be most thankful
