- 19 Oct 2008
Hi,
Not much of a DIY'er but trying to do a few things myself. I have bought different style mosaics to tile a splash back above three sinks. One set are staggered, so the panels slot together, which is probably a mistake as I'll need to saw and fit little tiny tiles to make the area square. I have also bought metal trims that come in a long length. I've watched a few videos, realised I need a hacksaw with HSS blades and possible a mitre box, but not saw any demo's of fitting trims around a splash back.
Question is, is it easier to cut and install the metal trim first and then fit the tile panels inside the fitted trims? That way I can take my time getting the trims the right length. If done afterwards I assume they have to be fitted before the glue dries. Or is it easier to do afterwards but aware of the time ticking away.
Another thought I have is to cut the tile panels to the size I need and place on a flat surface and then cut the trim pieces and place around, then once looks fine on my test bench (made up process) I then install the tiles first and then trims and should all nicely fit together.
Any advice on doing the job as easy and painless as possible much appreciated
