Fitting Tuniq Tower 120 To Socket 939
7 Mar 2005
The Voice Of Football
Hi all,
Just a quick question which I hope you can help with.
I have just picked up a Tuniq Tower 120 and am looking at fitting it to my DFI Lanparty SLI-DR socket 939 board to give my opteron 165 x2 a run for its money :)
In the manual, all the other sockets require a backplate to be fitted whereas the AM2/939/940 variants it seems you don't need to do this. Is this correct or am I going to end up with a cracked motherboard once I put it in?
Cheers for any input.
The TX-2 gets rave* reviews ;)
EDIT: Did I say rave :confused: meant good/can give AS5 a run for its money.
