Fitting your own wall bracket - help please
7 Nov 2009
Hey guys, I have a 32" Samsung LED (http://www.amazon.co.uk/Samsung-UE3...1?ie=UTF8&s=electronics&qid=1269967178&sr=8-1)
I would just like to know what I .. well "need to know" before I purchase it, apart from the bracket support size and weight, what other things do i need to take into consideration before fitting? And the obvious question, is it difficult to do?
edit: I just realised i need a specific Samsung WMN1000A bracket
i recently fitted my 32inch tv to the wall,
didn't realize at the time but the bracket kit i bought required a 1/2" drill bit.(homebase £5ish)
was a pain having to go back out to get one.
definitely check your wall construction, i was lucky as i was mounting to an outer wall which was solid brick, all my internal walls are plaster board and mounting on that would have been horrible.
