- 25 Apr 2010
- Ipswich
Hey Guys,
I have ordered these compression fittings.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-042-MO
For these hoses.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-136-XS
When it comes to 90 degree fittings do I need to screw a compression fitting into them then the hose into the fitting or the hose directly into the 90 degree fitting?
Either way can someone suggest some 90 Degree fittings that would work with that hose size?
Also OCUK is out of mayhems H20 and I need suggestions on a good liquid for my loop lol.
Thanks in advance.
For these hoses.
Thanks in advance.
