Fittings question
21 Dec 2009
Would the EK-PSC Adapter 90° G1/4 Black Nickel fitting (EAN: 3831109845141 on EKWB site) be compatible with this XSPC compression fitting?
The reason I ask is that all my fittings are XSPC and I need two 90° fittings but everywhere is out of stock of the XSPC ones with no idea when they're back in stock.
As long as it is a G1 Fitting which it seems to be then the compression should be able to screw into it as it will also be G1 threaded.
This is from what I know so it would be nice for someone else to come along and confirm what ive said :).
