[TW]Fox said:Could this mistake not be down to the fact you have an illegally spaced numberplate?
killsta said:Would that really matter though providing the letters are the correct font and size?
there are very specific regs concerning plates.killsta said:Would that really matter though providing the letters are the correct font and size?
Muncher said:does anyone have it bookmarked or can remember the URL?
They can take any plate off you if you're caught repeatedly, sticking you on a Q plate. Which'll shaft the resale value.andi said:Do have the right to take your private plate off you though.
are you sure that's correct?Nozzer said:...sticking you on a Q plate...
because in the UK the plate denotes the age of the vehicle.Nozzer said:Reasonably, why?
on what grounds?andi said:Yeah, you can be put onto a Q plate.
The_Dark_Side said:on what grounds?
the age of your vehicle wouldn't be questionable at all.if they were going to remove your private plate then surely you would be given a "dead" plate relative to the year your vehicle was registered?
As I understand it courts have the power to rescind a specific reg number if the user has been taking up a lot of police time with wrong spacing, fonts etc.
As these offences are not endorseable there are a number of folk who are quite happy to pay an FP every now and again in order to display their personalised plates.
The Q reg will actually be issued by the DVLA.
if that really is the case then i'm shocked.andi said:Don't know tbh, all I know is this, from oldcodger who is a JP..
