http://www.hardwareluxx.com/index.p...tage-regulator-for-skylake-and-kaby-lake.html
Good idea? Bad? There will have been two shrinks by then so density will be possibly making it even harder to cool than Haswell.
By integrating the voltage converter Intel wanted to simplify the power supply on the motherboard. Before FIVR, motherboards had to suppply five different voltages to the CPU package: Vcore, vgpu, VCCSA, VCCIO and PLL. In addition, this step was supposed to give Intel more control over the power supply of CPUs, which also created efficiencies in regards to power consumption.
Now, FIVR seems to be history for the upcoming "Skylake" and "Kaby Lake" processors, as Intel plans to release the two upcoming CPU generations without it. However, "Ice Lake" as the generation after next is codenamed, will then one again use a FIVR. A source not only provided us with the news, but also gave a reason: the thermal design power of the overall CPU package was too high. This seems to have had a negative impact on the overall system, Intel has to save the extra heat elsewhere.
