PROBLEM: Crashing at the end of every round (BF3.exe has stopped working) just before the scores come up and not being able to play single player.
I read a thread today on battlelog.battlefield.com showing how to fix the problem and it worked for me.
Hope it helps
SOLUTION: If you own an ASUS card (ATi or NV) and you installed the 'Smart Doctor' and/or 'ASUS Gamer' software then this is what's VERY likely causing you end of round crashes. All you need to do is uninstall Smart Doctor and/or ASUS Gamer, restart your computer and reinstall your video card drivers - that's it!!!
This has worked for me and I have had no crashes since. If you are having the same problem and this solution works for you then please post back confirmation for the rest of the community. Again, thanks to the original poster of this solution, you can have my hand in marriage!!!!!!!
EDIT: This problem may not be limited just to ASUS cards. If you have another brand of GFX card and installed overclocking software or any other software that came with it, try uninstalling it then reinstall your drivers and try the game again.
If you want to overclock your card use MSI afterburner.
Hope it helps
