- 26 Oct 2009
- London
Just purchased 6 new 180mm Silverstone air penetrator fans and promptly cut the plugs off (idiot) since I'm using them in a custom installation:
http://forums.overclockers.co.uk/showthread.php?p=27878911
Long story short, at low rpms 2 of them have a slight ticking/ vibration /whistle. I can see the hub isn't exactly true, but doesn't seem to be spot on on any of them.
Assuming I cannot return fans with the cable cut, is there anything I can do? I read about peeling back label and putting graphite powder/ oil in but is this even likely a lube issue? Any other suggestions?
