Fixed a weeping leak, how long will it last?
Permabanned
19 Oct 2022
London
Compression joint between hot water tank outlet and Hot water feed for rest of the house tap
Before
Sealant
After
It is dry now for half a day under pressure.
LS-X is basically a neutral silicon sealant and dries very similar to the stuff you use around the bath and window frames! Once set if it's not leaking within 24 hours then it will last for pretty much forever. It can easily deal with small gaps like that. Should be good for the life of the tank.
Or until someone whacks it with a lump hammer.
