Fixing Grub
1 Jun 2005
Kent
I just formated my windows partition to upgrade from win 7 RC to win 7 ultimate, and as expected it got rid of Grub and so I couldn't boot into Ubuntu 9.10. I followed this guide to fix Grub legacy by using a 9.04 live cd (put into a USB and made bootable), the problem is, after i run the grub-install command as it says to, it still just boots into windows. Even though it says complete and no errors reported, there is a couple lines that show up that mentions something about not being able to edit device.map or something like that.
Edit: This thread can be ignored/closed now. when the guide said replace /dev/sda in the install command with where you want it installed I thought it meant replace it with /dev/sda5, I tried again with just /dev/sda and it worked.
Well the guide said to make note of the /dev/sda5 and /media/disk stuff, So i just assumed when it said to replace the /dev/sda part of the install command that it wanted me to replace it with what it told me to make note of before.
Well its good that he found it himself and managed to fix it.
For most Windows users the pure existence of a boot loader is a concept they don't get..
