Fixing metal to wood
27 Dec 2005
Bristol
This isn't actually DIY related but crafts, but thought I'd get the best answers here.
I need to fix a 9mm diameter nickel-plated fixing to soft wood. What would be the best glue? I used to fix them to plastic and used superglue which whilst it sounds primitive worked very well as well as being transparent, however I get the impression that the wood might soak up a bit of the superglue as opposed to plastic. Any ideas?
