- 19 Oct 2006
I'm having a bit of a mare trying to fit some microwave brackets in the kitchen, normally I would use the plasterboard fixings where the outer part spreads behind the board but when I tighten the screw this board just seems to easily get destroyed. I have also tried the cone shaped fixing where you screw it in the fixing screw goes into that but when trying to screw in to the outer it starts spinning and comes away from the board.
Any ideas to save my sanity? Hopefully a simple solution as I'm a diy disaster.
