FLAC - WMA Lossless
20 Jan 2005
Hello All,
A few questions for you peps.
Are FLAC files completely lossless?
Can I convert FLAC files to WMA lossless files?
What software should I use? Any free software?
Can WMP play FLAC Files?
Can I convert from FLAC to WAV [ WAV is this the same file format as a CD ? ]
Cheers 4 your help
1. FLAC is lossless. I don't think there is even a lossy option.
2. Most likely. If not directly, I am sure some softwares could do via WAV.
3. Not sure, I haven't tried WMA lossless.
4. I don't use WMP, but I don't see why not if you have the codec.
5. Yes, and yes. Of course, if you convert to WAV, you lose the tags.
