Flag Weights/Accessories
28 Apr 2011
UK
Hello,
Does anyone know where I might buy a weight that you attach to a flag so when you release the string from the latch it will decent the flag?
Also I need a U shaped fixing with a bolt through the end of it.. I dont know what its called...
Can anyone help?
the string is inside the flag pole, it gets stuck at the top without a weight
Is the rope the right one for the pole, is it actually running in the pulley/guide at the top?
The propoer flag fixing are 'Inglefield Clips',or Snap Hooks, but you could use a small D shackle instead.
As above small D shackle or 'U' bolt.
You could also try a fishing / tackle shop for a lead weight that might work ust as good
