Flakey Net Connection On Main PC
26 Oct 2004
Up North
Hi.
The main PC on my network keeps losing its internet connection usually it's just not connected on boot up. Its a Windows 7 Pro x64 machine and the wireless card is Edimax EW-7727In nMax 300Mbs using the default drivers from the supplied disk (Windows hasn't found any new ones).
The internet is a standard Sky Wireless G modem/router. Due to issues with the mrs' laptop I've had to use WEP and have hidden the SSID.
I can usually get reconnected by running the trouble shooting wizard and it 'resets the adapter' and I'm online again but I don't get why it's doing it as it seems to be completely random on when it decides to cut out.
Weirdly its only the one PC that is affected as 2 laptops, 2 Android phones, 2 tablets and an Xbox have no connections what so ever.
Its not a massive problem but its really annoying!
Have you checked for new drivers on the Edimax site?
I'd start using WPA as soon as possible before some numpty abuses your network.
