Flash (ahhh)
8 Apr 2004
Wrexham
Well as my extremely sporadic posting on here might suggest, I've barely done anything with photography in the last year. I'm off to a family get together later, and again it dawned on me that I don't have a dedicated flash unit (still!).
Now I'm aware that there are a lot of mentions of flashes on these forums, so forgive me for asking here, but I'm after the most recent info I can get my mitts on :)
I've never researched much on flash information as what I was doing, and pretty much still do, involves daylight photography. I've spent today looking around at the lower end Speedlite flash units (and just missed out on one on an auction site for £40 :().
My question is this: With a Canon 30D, and baring in mind I'll mainly be using it for relatively small indoor events, which would be the best option? I've seen Metz ones, Sigma and Canon. Obviously for compatibility reasons I imagine the Canon range is the best to go for. My main issue is funding as I've just chucked a chunk of cash at a treadmill :D
With that in mind, is it worth getting the bottom end of the range flash unit, or would you say to go for something like the Speedlite 270EX over the 220EX? Are the other brands worth getting at the lower end? Recharge time isn't an issue really (as the longest I've seen is about 8 seconds, which is fine).
I just about got away with a higher ISO last time, but realise I need a flash.
An example of the last attempt. While okay, they're nothing great!
Oh, and would you recommend updating the firmware on my 30D, which is a couple of years old now and hasn't had an upgrade?
All help appreciated. Apologies for my ramble :D
Don't buy a bottom of the range flash, you need one that swivels and tilts because if you are indoors, you will be bouncing the light off of walls and celings.
Straight on camera flash usually looks pretty horrid unless you are just flicking in a tiny bit to lift the shadows.
You also need ttl. there are tons of models to choose from, the Nissin above, YongNuo are fairly popular too. The Canon ones tend to be better built but more expensive. Metz do some nice ones too.
YongNuo's YN-465 TTL is about £50 new and might be worth a look.
When you get the flash off the camera and onto a stand the angles start to sing and you can use cheap manual flashes too.
Last year I got a refurb 430ex (mk 1 not 2)for £127 from the Canon outlet store on eBay, apart from a little play not really used it. Need to get it out and make use of it really.
Hello my mexican brother.
I am looking at getting a 430exII with some diffusers to play with, i'd definately get the most flexible you can afford as even if you change body you can keep the flash forever
